Battery light on intermittently
As if I haven't had enough electrical problems with my 12 Heritage since the first week. Today the battery light has been on and off intermittently. This is the first time I've seen this light on. Any suggestions? I have about 3 weeks of warranty left. I swear this bike has been back to the dealership at least a dozen times for something electrical.
http://www.cyclefish.com/BikerNews/blog/2225/
Battery cables must be clean and tight, if not they can cause many issues such as display, ECM issues, sensor issues etc. If cables are clean and tight, the cheapest item to try is the battery itself.
I would still re/ck the cables on both ends and both cables
Check the error codes. It's probably catching some. If its not a battery connection I'd be thinking regulator or stator going out. If you don't know how to read the codes, stop by Harley. They'll check it for free. If it happens to be a stator, fix it under warranty, unless you just happen to have $500 you don't need..
I ran the codes and got P0562 which is low voltage. I'll get it to HD this week as it's still under warranty. Thanks for the suggestion.
I will also add that my wife's Low Rider was getting a battery light and generating both a high and low voltage error code. It was also cranking slow like it had a weak battery. Took it to Harley since I only had bought it a month earlier and what they found was a stripped battery connection bolt. So, like I said, check your battery connections first. It's a quick check..
Junior_co
Sep 27, 2012 09:26 AM
masterblaster
May 26, 2011 08:56 PM
