Elevation Adjustment - Need Help
Old Oct 5, 2014 | 12:49 PM
afalkowsky's Avatar
afalkowsky
Stage I
Default Elevation Adjustment - Need Help
I have a 03 Sportster 1200 and I just moved from NY to UT. Bike is not running as smooth and I believe it's due to the elevation. Struggles at higher speeds. I'm pretty new to bikes in general and I would appreciate any advice/instructions. I believe the carb needs adjusting, which I have no idea how to do. Any advice would be appreciated.
Old Oct 5, 2014 | 01:36 PM
Hammerhead Pat's Avatar
Hammerhead Pat
You are correct, your carb most likely needs to be re-jetted. An indy mechanic or a dealer could do it for you, probably an hour of labor.
Last edited by Hammerhead Pat; Oct 5, 2014 at 01:38 PM. Reason: additional comment
Old Oct 5, 2014 | 07:54 PM
John Harper's Avatar
John Harper
You might try adjusting/readjusting your idle mixture screw, lean it up, use the idle drop method if you can. Or, turn it in 1/4 turn and see if that helps.
Higher altitudes have less oxygen/air pressure, so you need to lean out your mixture somewhat. What is your altitude in UT?
John
Old Oct 5, 2014 | 10:40 PM
lh4x4's Avatar
lh4x4
Use lower octane even 85 will run much better at elevation. Try that first before spending any money.
Old Oct 5, 2014 | 10:54 PM
John Harper
Interesting, have not heard that before.
John
Old Oct 6, 2014 | 07:55 AM
grbrown's Avatar
grbrown
Hi from the UK and welcome to HDF. Mrs B and I were in Utah only a few weeks ago! I must admit that I would find a local friendly indy and get him to make the necessary adjustments. Bear in mind that if your bike already has mods, even as simple as a change of air filter or mufflers, it was probably already compromised before you moved home and the rise in altitude has just made that more pronounced. In other words you may need more than just minor adjustments to make your bike run well.
Old Oct 6, 2014 | 09:07 AM
mrfikser's Avatar
mrfikser
what carb is on the bike...From what I understand the keihnin (or how ever it is spelled) will compensate for altitude automatically...maybe you have another issue..
Old Oct 6, 2014 | 10:56 AM
Scrambler900's Avatar
Scrambler900
take to somewhere there and have someone adjust it for you. If you don't have any idea what you are doing with a carb that is the best method. If the bike ran fine in NY and now runs "rough" out west then it is elevation that is the issue.
HighwayStar
Jan 5, 2017 08:31 PM
MrsJMS
Ironhead
14
Sep 10, 2013 12:18 PM
dpk20x
Oct 5, 2011 06:54 PM
bgm2766
Aug 8, 2011 05:32 PM
HDRider76
Exhaust System Topics
Aug 27, 2005 01:52 PM
