What's the Difference Between a Race Tuner/PC III and a Fuel Pack?
RE: What's the Difference Between a Race Tuner/PC III and a Fuel Pack?
The PCIII is from Dynojet, the fuelPak is a V&H Product. Both do essentially the same thing..overide the lean 07 Sportster's ECM - I have a PCIII and like it a lot.
ORIGINAL: badbs101
I hear these terms used often. I know what a tuner/PC III does but what does a fuel pack do?
Hope this helps.
-FD
The PC3 is user adjustable and the FuelPak is not. Let me please clarify: The settings are kept from the user as "Propriety Information" by V&H, meaning they'll try to tell you what settings you'll need, but they won't tell you why. I have '07 883 with the V&H StraightShots HS slip-on pipes and tried the FuelPak with recommended settings. Ran leaner/hotter than stock. Never got a response back from CustServ about what settings to try. Ended up selling the FuelPak on EBay and buying a PC3, which explains "What does what". Hope this helps keep someone else from making the same mistake I did.
