Need advice on cables
Old 03-23-2016, 06:26 PM
c.d.lawns@hotmail.com's Avatar
c.d.lawns@hotmail.com is offline
Default Need advice on cables
First i have a 2012 iron 883.
I am looking at buying the licks 12 inch Fatty Aped Z's - Stepped-Black Powdercoated or
Licks 10" Aped Z Bars-Indented-Black Powdercoated.
I contacted Burly brand to buy their sportster cable kit to extend all cables to fit the 12 inch z bars. Burly email me and stated they will not fit z bars. Anyone have any ideas on a kit that will or if the burly brand really will fit?
Old 03-23-2016, 06:42 PM
drinktothat421's Avatar
drinktothat421
drinktothat421 is offline
you may just need a new brake line. i have a 6 inch zbar. and all my wires are fine, the stock throttle cable is very long. the 12 inch im not sure.
Old 03-23-2016, 08:55 PM
Iarecobra's Avatar
Iarecobra
Iarecobra is offline
In my opinion. The burly kit would probably work. There kit is designed so the electrical wires are internally wired. And it's generally not a good idea to internally wire Z bars. They were probably just trying to cover there own asses.
Old 03-23-2016, 09:57 PM
why are z bars not a good idea to do internal wiring?
Old 03-23-2016, 10:24 PM
Justin Lynn's Avatar
Justin Lynn
Justin Lynn is offline
It would just be a pain in the ***. I internally wired my bars and it wasn't that hard, but my bars have removable end caps on the bars to aid in making the wires turn corners.
here's a link if you're interested.
Road 6 Customs 10" Apes
For your cables, you should check out Magnum Shielding
I used a 48" 46848SW brake line
If you decide not to internally wire, you probably already have enough wiring stuffed up under that tank that you won't need to worry about that part.
Old 03-23-2016, 10:50 PM
everything i have read said you only have to replace the brake line for 10 inch. I will prob be running external wires bc of all the projects i am doing on the bike. Any ideal what size brake line i would need?
Old 03-23-2016, 11:08 PM
Justin Lynn
I used a 48" brake line for my 10" apes. It should be long enough for 12" apes if I were to ever change mine.
Old 03-24-2016, 09:40 AM
10 inch is sounding better
Old 03-24-2016, 01:48 PM
Iarecobra's Avatar
Iarecobra
The theory is.....with the sharp bends on Z bars you have a greater risk of rubbing or breaking the wires and causing a short.
Old 03-24-2016, 05:04 PM
i can see that. I guess i am going with 10 inch bars. I am going to try to find a brake cable. I have read and been told for 10 inch z bars you only need to replace brake cable.
Quick Reply: Need advice on cables
