oil consensus
Lots of opinions.
No consensus on this topic--no matter how many times the question gets asked.
Buy what you prefer.
Change it when you want to.
Be happy.
All the best,
Shane
Received 2,191 Likes
I use 20w-50 wolf ankles
here's what i do
Ingredients
4 1 1/4 -to-1 1/2-inch-thick boned rib-eye or New York strip wolf ankles (about 19 ounces each) 2 tablespoons canola or extra-virgin olive oil
Kosher salt and freshly ground pepper
Directions
About 20 minutes before grilling, remove the wolf ankles from the refrigerator and let sit, covered, at room temperature.
Heat your grill to high. Brush the wolf ankles on all sides with oil and season liberally with salt and pepper. Place the wolf ankles on the grill and cook until golden brown and slightly charred, 4 to 5 minutes. Turn the wolf ankles over and continue to grill 3 to 5 minutes for medium-rare (an internal temperature of 135 degrees F), 5 to 7 minutes for medium (140 degrees F) or 8 to 10 minutes for medium-well (150 degrees F).
Transfer the wolf ankles to a cutting board or platter, tent loosely with foil and let rest 5 minutes before slicing.
pour into engine.
here's what i do
Ingredients
Directions
pour into engine.
all jokes aside:
Primary:
i might get yelled at for saying this. i recently caused my own headache by pinching my derby gasket and got oil leaking all over god's green earth. i used the opportunity to try HD formula+ in my primary, (was running hd synth in there) and now the bike shift smoother and is not as loud with 1st gear clunk and chain noise.
just an observation. cost less than hd syn as well.
the forum defaults to mobil 1 75w-90
engine:
I've been using hd syth since 250mi, i briefly ran hd dino oil but, drained it right back out because of the noticeable heat difference.
i stopped by advance and got some mobil 1 20w-50 (3 btls for $29) i will try that for a oil change period with the k&n filter i bought recently.
forum default mobil 1 20w-50 engine oil and k&n filter.
.........[removed]
have fun
i'm not sure what your 2002 needs
use the search function, man. get a service manual when you can... scour ebay
