Trying to Change Primary and all went to hell...
Old 06-26-2016, 12:32 AM
Troops141's Avatar
Troops141
Troops141 is offline
Always take the foot rest off if you are going into the derby cover.. I'd try to cut the screw head with a dremel and use a flat head screwdriver. Worst case, you damage the derby cover and then you have an excuse to buy one with a design on it (they aren't bad priced). Get new screws from your dealer.
Old 06-26-2016, 07:26 AM
chugger93's Avatar
chugger93
chugger93 is offline
OH ok....so I can put the oil thru that inspection cover, that should be fine. I have some long funnels that should work. Then I can just leave the stripped screw for now.
I'll have no reason to take it off if I can just put oil in thru that small cover for chain. Thanks all!!!
Old 06-26-2016, 12:19 PM
gearhead1937's Avatar
gearhead1937
gearhead1937 is offline
Replace the torx with allen head. Much easier next time. Every time I take a torx out it gets replaced.
Old 06-27-2016, 01:48 PM
deadrubberboy's Avatar
deadrubberboy
deadrubberboy is offline
You will eventually need to remove the derby cover for other adjustments. Filling through the inspection cover solves the immediate issue. Address the stripped screw. Address the stripped screw prior to needing to be in there. That way the next project won't begin with frustration caused by a past mistaken left unfixed.
Also, look at the service manual and youtube videos (Delboys garage is great) BEFORE you start the project to know what you're getting into/doing.
Old 06-27-2016, 04:36 PM
KCCO-Forty Eight's Avatar
KCCO-Forty Eight
KCCO-Forty Eight is offline
Lightbulb
Where would I get a new screw then do you think?
http://partsfinder.onlinemicrofiche....b=7&c=0&d=2007 SPORTSTER® XL 883L (CR) INSPECTION COVER W/ PRIMARY COVER
#1 Part Number 943 $0.49 Each
Don't feel bad, I recently had to replace #12 on mine when swapping out the chain inspection cover.
Old 06-28-2016, 05:39 AM
grbrown's Avatar
grbrown
grbrown is offline
Received 2,853 Likes on 2,420 Posts
Exclamation
wait...wheres this derby cover? What are the methods to fill the primary. I'm only familiar with reading the manual and it saying thru the inspection cover which is what I was taking apart. If I can do it another way, I will just do that and leave the stripped screw alone for now. It's not doing any harm.
Oh and you are right..I was using T25, didnt think it was anything higher. Didnt even have a T27, nor own one, but yes it stripped pretty quick. Learning lesson!
It doesn't sound to me as if you are using a factory service manual! That tells you to use a T27, also to remove that footrest and how to do so.
Old 06-28-2016, 05:59 AM
stereoguy's Avatar
stereoguy
stereoguy is offline
Yep, no service manual and I am thinking he doesn't need a service manual as much as he needs a good Indy, seems to be dangerous with tools in hand.
Old 06-28-2016, 06:29 PM
cvaria's Avatar
cvaria
cvaria is offline
Received 2,189 Likes on 1,677 Posts
just to be fair...mine (none of the ones i have) make no mention of t27 until the hand controls section (searched it just now)... he doesn't have a manual yet.
be nice, tons of us did the same type of stuff and learned hard lessons
for years i had this as my avatar, because i kept breaking s***:
i tried to warn him but, it fell on deaf ears.
Mr_Taipan (06-28-2016)
Old 06-28-2016, 09:35 PM
langwilliams's Avatar
langwilliams
langwilliams is offline
I picked up this set for like $30 at sears an it's handy for Harley....every common size is in the set...pretty good quality...not snap on quality but it's not $550 either...anyway this is handy for jobs like that, you can try dif ones...sometimes it feels like a fit but there's another one that's really the correct one...using a T25 in a T27 for example"
Old 06-28-2016, 11:21 PM
GraemeR's Avatar
GraemeR
GraemeR is offline
Or o to a inkjet ink supply shop and buy a massive syringe (about $5) and use that to both measure and inject the oil into the case. Or pick one up on ebay.
vindyl
05-01-2010 09:31 PM
bloozeman2002
06-16-2009 10:53 PM
meatball
05-25-2007 12:38 AM
Taterdog
03-27-2007 01:27 PM
Frankster69
05-05-2006 12:58 AM
Quick Reply: Trying to Change Primary and all went to hell...
