Sportster / clicking rattling noise when hot
2000 Sportster XLH 1200
9000 miles
NOTE;
This Motorcycle was sitting in storage for 8 years.
When starting off in first gear, engine hot, there is a clicking rattling noise that seems to be coming from the left side of the engine. The primary chain is within specifications; 3/8"-1/2" at the tightest point when cold. The primary oil is up to the correct level. It is also difficult to locate neutral when the engine is hot and standing still. I can locate neutral easier before the bike comes to a complete stop. This may be coincidental.
Does anyone have any ideas what could be causing this?
thank you in advance
Robert
9000 miles
NOTE;
Robert
Hello and thank you for replying.
Yes I am new to the Sportster. Just got it 1 month ago.
I don't mind the mechanical noise (my first bike was a 1968 Triumph)
This noise is not normal. I am advised it may have some thing to do with the bike sitting for 8 years, the clutch plates being effected. What say you?
I will do as you suggested and attempt to send you an audio clip.
thank you
Robert
thank you
Robert
You should be able to tell when draining the fluids,
if you see sludge in primary then you might want to take the clutch pack apart to clean it. If there is no sludge, then you should be ok.
Also, make sure to replace your brake fluid and replace the brake lines, they are passed their expiration date, and it does not cost that much to do.
And also replace your tires.
thank you
I'll look into the primary for sludge. May need to take the clutch pack apart to clean though. I was looking for another option to that. There may not be any.
I did change the brake fluid in the front and the pads. Has Dot5 fluid and it did get contaminated.
Tires in the near future
Riding for a while to get the fluid well distributed (it appears to be very clean and has no odor) then drain it.
I adjusted the clutch at both ends.
The noise persists.
Also,
Is it normal for the bike to lurch forward slightly and momentarily when starting with the trans in 1st gear and the clutch depressed?
Also,
Could the noise be carbon build up in the heads from the previous owner?
thanks to all,
Robert
The noise persists.
Also,
Also,
thanks to all,
Robert
The noise persists.
Also,
Also,
thanks to all,
Robert
The noise persists.
Also,
Also,
thanks to all,
Robert
