Sportster newer style fork questions
Im looking into updateing my forks now. Was going to use race tech, but not sure now. My 18 Iron forks use the new style forks that has two different internals. Im torn between a Honda xl600 conversion or a set of older sportster forks, then add some 2 inch longer tubes and update the internals with new springs and gold valves.
I want to gain more travel, and better suspension action. Im not sure if the brake caliper mounting tabs are different on older tubes. Mine is a single disc. Also not sure if I can just buy a new lower tube that accepts a spring to match the one on mine. I also have not figured out which fork tube has the spring and which tube has the cartridge or whatever its using.
The emulaters just seem like more added complications in adjustment, which is not what im after at this point. I just want to raise the travel a inch or so, which the extended damping tubes will allow. And get a better responce from the front end. Which the springs should help with.
After doing some research, I think I will pass on the emulators for now. Im just going with the cartridge eliminator kit along with the extended length damping tubes, new race tech springs and the preload adjusters.
