Sputtering after baffle install
I just did two things to my Sportster. I adjusted the throttle, and installed Vance & Hines Super Q Quiet Baffles.
The baffles sound great, exactly what I wanted. However, the bike is now sputtering and popping.
No stalls, but I felt like it might. What is the likely cause of this? How do I fix it?
The pipes are Vance & Hines Shortshot Staggered, and I removed the stock baffles.
It also has a Screaming Eagle filter.
So I let my exhaust cool down to put the heat shields back on.
After I started it again and it was much smoother, a pop or two but mostly smooth.
What is going on? Did the ECU do an adjustment?
I haven't ruled out a good-hearted gremlin.
The baffle may create a little more reversion but will not affect the air to fuel ratio in a significant way. Once the exhaust leaves the motor the AFR is already determined.
