Battery voltage drop when starting
I'm seeing a battery at rest with just under 13 volts, as soon as I hit the starter the voltage drops to 9.96-9.98. As soon as the bike starts the voltage is right back up to 14 volts, so the charging system is working fine.
The bike is a '17 1200 Custom, is that amount of voltage drop when starting 'normal'? I had the bike set a code that can be caused by low voltage, loss of PCM communication. The bike runs fine, and ran fine with this code set.
I have no idea how old the battery is.
Mongo1958 (03-10-2024)
How old is your battery? Have you load tested it? Sounds like it's on the way out.
One of our members, tcup, is having issues with a trouble code, similar to what you had. Perhaps you can pop onto his thread and help.
https://www.hdforums.com/forum/sport...-xl-1200c.html
John
John
firehawk6 (03-07-2024)
The 883 spins right up when starting, the 1200 seems to struggle the first couple of rotations when engaging the starter.
Received 1,513 Likes
Received 19,645 Likes
Tom H (03-07-2024)
John
Normal and that is a good result, 9.6 volts DC minimum while cranking is a spec I've seen published by Bosch and others. I worked as a generator tech for a few years and that was a standard test we did when performing repairs or maintenance.
No big need to use a load tester on the battery, starting (and seeing an acceptable voltage drop) IS a good load test. Some useful info is in the PDF below...
https://www.boschautoparts.ca/docume...%20Systems.pdf
The following 4 users liked this post by 08xl1200r:
John Harper (03-07-2024)
