Help.... Oxidation
If it's engine paint, you could remove it first with Aircraft Remover, then repaint the cam cover with Harley engine paint, or just leave it bare and hit is with some non-scratching ScotchBrite pads. A good scrub with some small brass or ss brushes and soap and water should clean up the rest.
https://www.rustoleum.com/product-ca...rcraft-remover
John
John
The damage is already done, the only thing you can do is wash it off and/or use some of the products above to get the corrosion off, then spray/paint/apply an anti-corrosive to limit further damage.
You can paint over the black areas to improve the visual look.
You can polish the aluminum somewhat; however, you are not going to get any pitting out.
You should also check all your connectors to ensure migration of the salt corrosion did not get past the connector seals.
You should check all your fuses and behind the fuse holder to ensure they are not corroded and will cause issues later.
You should check both ends of your battery connections and all frame grounds to ensure they are corrosion free and tight.
OC, those pads are cool. I bought a cheap kit with the grinder. Surprisingly, the grinder is a nice piece.
With that said, I live in California and don't have to deal with road salt so I have it a little easier. A little elbo grease and I think you can get that cleaned up pretty well.
