I'd suggest changing your intake manifold seals, ditch the Dynojet kit, go with a 170/45 main/pilot combo and 2.5 out on the idle mixture screw. Maybe buy a CVP Velocity needle or just leave the stock one in place. Check your plug color and use the "idle drop method" to fine tune your idle mix screw. A 1200 should be able to take a 170-175-180 main jet.
John
Years ago when my new '91 1200 was not performing properly. The dealer cured it when they discovered a 'burr' on one the carb jets.
Wow, that's doing some really good diagnosis. I've found that clogged pilot jets cause more problems than any other issue, especially if a bike has sat for any extended time.
