forward control extensions???
My brother has an 01 1200C... he is 6ft and a bit cramped up... i see in the how to section you guys have there is a write up on how to make a forward control ext kit... it just does not make since to me... does anyone on here make them? or know where i could pick up a set pretty cheap? thanks!
Stop by a machine shop, us machinists are a pretty resourcefull bunch, as most of us ride too. I'm sure there will be someone there that can either do the job or help you to do it.
I bought mine from Harley and they were pretty reasonable price and easy to install.
Only problem was one of the new motor mounts bolt holes was fudged up. Luckily we had a tap set available to use to fix it.
one of the forum members got this:
http://cgi.ebay.com/ebaymotors/CUSTO...spagenameZWDVW
I am doing the DIY mod on mine. Got everything cut, drilled ready for welding.
I am not sure how the oher mods are, but the DIY mod does not work with std pipes
ORIGINAL: JRK5892
sauvdogg
May 11, 2013 11:26 PM
