Lever Vibration and Noise
Both my clutch and brake levers have some up and down play, causing them to vibrate when accelerating. I have remove the retaining pin and bolt, making it obvious that the bolt is about 1/16" too long. They are factory, and can be pushed up and down when installed tight (as tight as they can be). I can grab either lever and shake them up and down. Does anyone have any suggestions to resolve this? Thanks in advance.
RE: Lever Vibration and Noise
I checked the inserts, and they are not worn. Good idea though. The movement is actually up and down, leading me to believe that there should be a rubber spacer between the inner portion of the lever housing (top and bottom) and the lever itself. But, this might obstruct rotation. The rod that holds the lever in place with the spacer ring, simply seems too long.
Its a 2003 - 1200 Custom. I just spent some more time trying to dampen sounds, and have actually found that the lever is only a part of the issue. The mirror is vibrating the most, with some metal on metal sounds down the front forks. It might be one off balance, causing it to transfer. I am playing with the mirror, now, but I think it might be loose internally. Thoughts. Its not free moving, to the head of the mirror seems to be intact.
NCHD
2014-2023 Touring Models
24
06-11-2017 08:38 PM
