Brake light switch
Brake light switch
Had to remove my (aftermarket) throttle grip because the end cap fell off and I may have damaged the switch. S**t!
When I turn on the ignition to test the brake light, neither the front nor rear peddle seems to light the lamp.
I did put a wooden wedge in the lever. How fragle is the thing? I pressume keeping the lever in prevents he actuator from being sheared off or damaged when overlapping the lever.
I don't believe I hurt it. I can hear it clicking.
Thoughts and suggestion appreciated.
Do it again! They are fragile but you really have to work hard to break one (at least I haven't yet... and I drink scotch) and I don't use the lil' 5/32" cardboard; I just be careful when reassembling! May have just misaligned it and the lever is keeping the switch on & brake light is staying on (otherwise rear brake would work).
