Clutch Adjustment
Old 04-29-2009, 04:30 PM
Moose69's Avatar
Moose69
Moose69 is offline
Originally Posted by Sick1200
If you want immediate clutch response adjust it again at the derby with the clutch cable completely loosened (apart) and tighten the nut til you feel resistance then slightly back it off. Not 1/8 of a turn or 1/4 of a turn but just slightly turn it off the resistance point.
I will try that when it cools off. What is your definition of 'resistence' :
1) first time I feel 'tension' turning the screw ccw
2) the point at which there is enough 'tension' that you would put a little final umph to tighten - like finishing a screw a hair past flush?
But from what it seems your saying - its the back off that has a bigger part of the friction point so I will keep that in mind.
This is an R....it would have been cool if the designers could have thought about it one more day before placing one of the derby bolts behind the peg. Not a big deal...just sayin.
Old 04-29-2009, 04:38 PM
Grammaton's Avatar
Grammaton
Grammaton is offline
Loosen the screw (turn it clockwise) a full turn. Tighten it slowly until it feels different. That is tension.
Old 04-29-2009, 05:26 PM
Sick1200's Avatar
Sick1200
Sick1200 is offline
+1 exactly what he said, as soon as you feel that difference take it back a blonde c*nt hair
Old 04-29-2009, 07:06 PM
Moose69's Avatar
Moose69
Moose69 is offline
I know how thick those are so I should be good!
Gramm - good trick on going clockwise first I will try that too.
peepa
General Topics/Tech Tips
16
10-01-2016 05:36 PM
Terry D Kemp
05-23-2014 05:28 PM
Kebo
06-07-2012 03:16 PM
pk
06-17-2010 09:02 AM
DAWG_6
07-29-2007 06:28 PM
Quick Reply: Clutch Adjustment
