Oil Leak - Primary Chain Inspection Cover
Old 06-13-2009, 12:31 PM
tiger_rider's Avatar
tiger_rider
tiger_rider is offline
Default Oil Leak - Primary Chain Inspection Cover
I have a leak coming from behind the inspection cover, the small plate above the gear shift. The bolts holding it in place are tight. Is this likely to be a gasket problem or a sympton of something more expensive?
Old 06-13-2009, 12:36 PM
Gpsjr10's Avatar
Gpsjr10
Gpsjr10 is offline
Be sure the gasket and surfaces are clean, if they are then get a new gasket and o rings.. make sure the o-rings are under the bolt heads.
Old 06-13-2009, 12:42 PM
killer scott's Avatar
killer scott
killer scott is offline
Is it leaking or just kind of seaping? I guess either way, it is probably the gasket or o rings like said before. should be an easy fix.
Old 06-13-2009, 12:57 PM
RATROD HOG's Avatar
RATROD HOG
RATROD HOG is offline
need new o-rings or gasket
the bolt holes are not blind holes (thru the case)
Old 06-13-2009, 01:00 PM
RATROD HOG's Avatar
RATROD HOG
here are HD parts #'s
o-rings-11171 (2)
gasket -34986-04
Old 06-13-2009, 01:01 PM
SpursDarkrider's Avatar
SpursDarkrider
SpursDarkrider is offline
Be sure to get the correct gasket. Moco came out with a thicker stiffer gasket but it only works with the new cover. In other words, new style gasket doesnt seal well with old style cover.
Old 06-13-2009, 01:19 PM
tiger_rider
Thanks guys!
Definitely a leak, it comes out whenever the engine is running takes about 5 seconds before its dripping on the floor.
I'm off to the dealer to get parts
Old 06-13-2009, 03:05 PM
DPete's Avatar
DPete
DPete is offline
Big Kahuna HDF Member
Received 1,729 Likes on 1,302 Posts
I had that happen on my 07 1200c, there is an upgraded cover that will stop it. the new cover is machined deeper inside where the 2 screws are and will compress the gasket better, I always thought it was the gasket or orings and it was the NFG cover all the time. If it leaks much it will blow back on the rear brake,
Old 06-13-2009, 05:05 PM
128auto's Avatar
128auto
128auto is offline
HD has a new updated paper gasket that fixes the problem, the original rubber gasket is junk, change the o-rings too.
Tralfaz
07-31-2022 04:50 AM
Bobkat
09-09-2011 10:14 AM
urleycay
04-24-2010 04:08 PM
faber
10-05-2008 08:53 PM
mjaw
EVO
05-28-2008 10:26 AM
Quick Reply: Oil Leak - Primary Chain Inspection Cover
