Fuel Pak w/o High Flow AC
Old 06-25-2009, 03:47 PM
tumbleweed883's Avatar
tumbleweed883
tumbleweed883 is offline
Default Fuel Pak w/o High Flow AC
Do you guys know if I can add a Vance and Hines fuel pak without adding a high flow air cleaner? I ordered my pipes and my fuel pack today, but I think I should wait to get my air cleaner before I install the fuel pak. Any thoughts?
Old 06-25-2009, 03:54 PM
brightboy90's Avatar
brightboy90
brightboy90 is offline
what is a fuel pak?
Old 06-25-2009, 04:02 PM
FunkyFungus's Avatar
FunkyFungus
FunkyFungus is offline
I don't see any reason why you couldn't install the fuel pak and modify the curve again once the AC is installed.
fF
Old 06-25-2009, 04:07 PM
tumbleweed883
Originally Posted by brightboy90
what is a fuel pak?
It is a fuel management system that plugs in to the ECM. It changes/reprograms the fuel/air mixture after you have changed the airflow by adding a high flow air cleaner.
Old 06-25-2009, 04:59 PM
hollywood1959's Avatar
hollywood1959
hollywood1959 is offline
If you go to V&H web site, follow the link to the fuel pack. It will ask you , make, model, year, bla bla bla. When you do put in a hiflo AC. you will have to change the map again. Just to get it in is a real PITA! You have to move around a few clips and wires, but well worth the trouble. You may get a few bloody knuckles. Putting in the numbers is the easy part just follow the directions. Hit it back if you need some help. HOLLYWOOD........
Old 06-25-2009, 05:22 PM
tumbleweed883
Yeah, I've heard that getting it into position and tucking away the wires was the biggest problem. Can't wait!
Old 06-25-2009, 07:53 PM
coze's Avatar
coze
coze is offline
So does a fuelpak or power commander etc add horsepower?
Old 06-25-2009, 08:08 PM
tumbleweed883
You could get a few extra ponys out of the whole stage one...But I'm starting to think I'll just wait until I get the air cleaner. Fuelpak and stock ac wont do a thing for me or the bike
Old 07-01-2009, 07:12 PM
smjul90's Avatar
smjul90
smjul90 is offline
You can but you should add more air the the system, At least get a better air filter from K&N
autobarry
15
08-16-2015 09:31 AM
OORAH1
10-14-2013 06:01 PM
Harleyfirst
VRSC Models
05-23-2011 02:41 AM
honkerdown
09-25-2009 11:04 PM
fabricatorfbf
07-23-2008 01:03 PM
Quick Reply: Fuel Pak w/o High Flow AC
