Rear Lights not working on Sportster
Step back, and take a deep breath...It`s a 24year old machine, be prepared to spend some time taking care of it.
Those components are powered by the accessory circuit.
Check the accessory fuse.
I checked it ,it kept blowing until I found a wire touching under my tank fixed it and now the fuse don’t blow but still don’t have any lights
The problem is in the accessory circuit, just for the hell of it, check the accessory fuse again...
Do you have a voltmeter?
when you turn the bike on the taillight comes on but does not do anything when you hit the foot break or hand brake. just tore tank off and found pinched wire that kept blowing my accessorie fuse, threw a fusse in and now it dont blow as soon as i hit the key, But still no tailight.
I have a 99 sportster xl1200 and the fuse box is just to the right of the battery behind a plate. You can just pull it out without taking off the plate and the fuse box slides out.
I have a different problem with my lights. Everything works except for the back running lights, but the turn signals work which makes me think it's not a bulb. I changed all the fuses and the breaker under the seat is not tripped.
Anybody have an suggestion?
I'm gonna check out heavy duty lights, possibly LED if that doesn't work.
Who all is going thru this issue? Is this why theres so many older models sitting in garages with low miles?
bighosschato
Electrical/Lighting/Alarm
Apr 18, 2014 12:12 PM
Chaseg08
Nov 22, 2009 04:02 PM
NoBoZoS
May 7, 2006 12:48 PM
