Drilling Bars
When I mentioned it to her she told me it wasn't a good idea as it would put the structural integrity of bars in to question and said if I wanted them to do it at the shop (yeah right) they would say no.
I know a lot of guys on here have done but would like some other thoughts on the subject...
Thanks in advance
Perhaps you guys remember a few recalls and mods associated with HD bars cracking/breaking.
For the most part, the shorter and narrower your bars, the safer it is to drill them. Then you need to carefully grind out any sharp edges to relieve stress risers that can lead to cracking.
Anyone thinking apes needs to insist on thickwall, quality made bars. HD does sell some decent bars already drilled and designed to work safely.
Thanks in advance
I ran them about a week and decided they were flimsy junk...I gave them away and elected to go with DOUBLE WALLED 1 1/4" 14" tall Wild1 Chubbys.
Man , you shoulda seen me strain to lift the box those bars came in......Those bars are more than twice the wall thickness and 10 times more rigid than anything HD sells OEM....They also feel 5-10 times as heavy when you pick them up.
Those guys at Wild1 don't weld their chubby bars. What they do instead is use two pieces of thick walled tubing-one inserted inside the other-then they bend and chrome them....no welds to crack, and no flexing/cracks/breaks, either....and yeah, they come drilled already with no worries about being drilled properly.
RSD also makes super quality bars drilled properly and made of thick high strength steel.
Just sayin..........
I would not do it
Assemble the complete set of controls and grips just like they would be installed once complete....Then use masking tape to locate on the bars where the switch housings fit(because the holes in the bars must fall under the switch housings and not the lever clamps.....
Then "clock" the controls by rotating them to where you want the levers, and mark the masking tape to reflect dead bottom center where the wires shoul enter the bars.
Remove the controls/grips and switch housings and turn the bars over to reveal the bottom side...from there lay out your holes staying tween the tape that marks the width of the switch housings and use the clocking marks to place the holes radially.....(The 'holes' must actually be 1 1/4" long slots/elongations that are rounded on each end, yet still fall only under the width of the switch housings.)
Locate the ends of those slots and drill a 7/16" hole at each end, then use a dremmel with a thin cutoff wheel to connect the holes. That will create the elongated holes or 'slots' you need to run the wires inside the bars...from there use a conical shaped grinding tip on your dremmel to ease any sharp edges, and then lay out and do the same for the elongated slot tween the riseres where the wires will exit the bars.
If you are workin chrome bars, then seal the raw metal you exposed with clear silicone...if you are workin black bars tho, then seal with Krylon Satin black spray paint.....simply spray the Krylon into the spray can lid till it pools and then use a small model brush to paint it on....The silicone, you simply spread with your finger tip and let dry.
