superbrace & big thanks
Hi guys,
I was thinking about buying (when will my purchases ever stop?) a superbrace for my '09 Sportster Iron and was just wondering if anyone has fitted them. Do I need to lift the bike off the ground to fit it or can I simply just bolt it on? I ride with mainly sports bike guys and need to keep up on those twisties (yes, I do understand it's a Sportie not a GSXR) with a bit more confindence.
Oh, and a big thanks to everyone I spoke to about installing the RK shocks, did it this weekend and it's a huge improvement!!! Even the missus mentioned it was more comfatable!
Thanks in advance.
Thanks in advance.
Hey dog, I have a superbrace and am waiting to instal it as well. Item #3 on the instructions states to 'Loosen the axle caps or pinch bolts to allow the forks to relax'. I recall reading that folks have installed the sb without taking tension off of the forks, but I can't quote that. I would have already installed the brace but am waiting for more info, or a getting a hold of a smaller jack to lift the front wheel off of the ground, which I believe will do the job. I'm not in for loosening anything up.
you can install it without loosening the pinch bolts; it will appear too small when you do it though. It snugs up fine, but if you unload the front end with a jack, or loosen the pinch bolts. it slides right into place. Makes you realize how much flex there actually is on a sporty. BTW, it is the single best handling improvement I've made, no question. Really dials in the handling, better cross-wind control, etc.
Hey guys,I too installed it on my 09 iron.Wasnt to sur either when installed it whether to put on lift.So when in doubt I called tech line..didnt need to be put on lift.Just keep wheel pointed straight and they did say to loosen the pinch bolt.It was a snap,took all of 10 minutes.I have to agree w/Dragan..hands down def big improvement on front end handling.Handles great at 70mph plus,before I felt like front was starting to lift didnt feel planted.
Brace good for tarlines/road ripples?
Hey all
Just joined you from over here in springtime UK (=cold, windy, but dry!)
Got my 09 Nightster last August - changed front springs for progressives (ex! - stops her bottoming on every UK pothole) and fitted Avon Venoms for grip. But, our roads are FULL of tarlines and wear grooves and she always feels skittish, like she's being kicked left and right a bit. Unsettling!! So, would a brace help?
And, are there any around for sane $$$??
Thanks in advance
Ciao
marker
Thanks in advance
Ciao
marker
Hey all
Thanks in advance
Ciao
marker
Thanks in advance
Ciao
marker
Hi hungover
Standard stuff - Front 100/90-19 57H , Rear 150/80B16 77H. Good rubber - felt really secure first time I took 'em out before Christmas but the ice and snow seems to have knocked 7 bells out of the road surfacing since and while the rubber still feels grippy, the front feels like it's always being nudged sideways by the road ripples - that's why I'm considering a brace. I can afford either the brace or a pair of Hagon shox for now - which do you reckon will make the ride feel more planted?
Where are you in Blighty then?
