Help
Old Mar 20, 2010 | 04:20 PM
duigon177's Avatar
duigon177
6th Gear
Default Help
Here is the problem, i put handlebars on over the winter and broke the little plastic switch for the front brake. I got the new part and installed it and everything worked fine (blinkers and stop lights). Went up the street and hit the turn signal it worked and then went out as well as the brake lights(running lights are still lit). I tried to by a manual but the dealer is out. Is there a fuse box. Any info would be great its to nice out to be in the house.
Old Mar 20, 2010 | 04:42 PM
cHarley's Avatar
cHarley
The fuses are behind the side cover on the left side of the bike.
Old Mar 20, 2010 | 04:50 PM
duigon177's Avatar
duigon177
6th Gear
Your the best thanks man
Old Mar 20, 2010 | 11:44 PM
SportyPig's Avatar
SportyPig
If it's not the fuse, I'm afraid to say you might have broken that little plastic front brake switch again. It's quite delicate.
Did you use a piece of cardboard between the front brake lever and the housing? If you didn't, it's probably broken.
Old Mar 21, 2010 | 08:00 AM
duigon177's Avatar
duigon177
6th Gear
Nope it was a fuse. Got a manual on order. Thanks again cHarley at least I was able to get out in this beautiful weather.
Old Mar 21, 2010 | 03:25 PM
Gpsjr10's Avatar
Gpsjr10
Duigon,
Your bike reminds me of Odie with those apes. See the resemblance?
GalvTexGuy
2014-2024 Touring Models
Jan 12, 2018 09:37 AM
dustin1014
Sep 7, 2015 09:19 PM
jckazz333
Oct 29, 2011 11:08 AM
joebotics
Jul 7, 2009 09:22 PM
HDRider2002
Nov 14, 2008 07:38 PM
