Brake lights won't turn off
Old Jul 25, 2008 | 09:26 PM
HDRider2002's Avatar
HDRider2002
Default Brake lights won't turn off
my 02 Road King has recently began running with the brake lights on constantly.&nbsp\\; I check to make sure the switch in the handlebar is good, and in doing that i realized the brake lever is not putting enough pressure on the switch to keep the brake light off.&nbsp\\; The pads are in good shape, the fluid level is good, but still there is some "wiggle room" which makes the brake lights stay on.&nbsp\\; I am running the diamondback cables and the chrome master cylinder which were installed roughly 2 years ago.&nbsp\\; Does anyone have any suggestions as to what i can check to fix this problem?
Old Jul 25, 2008 | 09:38 PM
shooter537's Avatar
shooter537
Default RE: Brake lights won't turn off
HDRider, If the light goes out when you push outward on the handle then the problem is for sure in the switch. Loosen the two allen screws that hold the front brake assembly. Squeeze the brake assembly and the switch housing together and re-tighten the allen scews. The only thing I would suggest that you check is the switch housing. Most switches are held into place with a copper wedge that slides behind the switch itself and the cavity in which the switch sits in. Make sure the cooper wedge is in place. Good luck.
Old Jul 25, 2008 | 09:44 PM
HDRider2002
the lights DO go out when i put forward pressure on the lever (manually returning the lever completely).&nbsp\\; I guess i will have to take the housing apart and see if that copper wedge has slipped loose but i know the 2 halves of the housing have not separated.&nbsp\\; Thanks for the quick response i'll take a look at that in the morning.
Old Jul 25, 2008 | 09:47 PM
Taterdog's Avatar
Taterdog
Had same problem on my bike.&nbsp\\; Dealer found it.&nbsp\\; Weak spring on foot brake.&nbsp\\; Easy fix.
Old Jul 25, 2008 | 09:52 PM
HDRider2002
This problem is definately in my front brake lever though, and unfortunately there is no spring in the front brake lever &nbsp\\; i'm hoping its as easy as that copper wedge not pushing on the switch.&nbsp\\; I have also had suggestions from others that the piston in the master cylinder might need to be cleaned, anyone ever had to do this?
Old Jul 26, 2008 | 02:36 AM
whatzleft's Avatar
whatzleft
I had this happen on my 04 ultra, exactly what you are talking about.&nbsp\\; My cruise wasn't working and I found the same thing you did, the switch was good but the lever wasn't making the switch to make the brake light go off.&nbsp\\; In thinking back I remembered that I had Kury levers... ahhh the aftermarket blues had hit me!!!&nbsp\\; What I did for a fix was take some round heat shrink and shrunk it over the piece on the lever that makes the switch, more or less built up the area on the lever.&nbsp\\; I would shrink a piece, then put another piece on, think it took me about 3 pieces of shrink before it was built out enough to make the switch.&nbsp\\; Been on there now for about a year, and have had no problems.&nbsp\\; Nice cheap fix.&nbsp\\; &nbsp\\;
Old Jul 26, 2008 | 12:30 PM
HDRider2002
so you put the heat shrink on the lever...not the switch right??
Old Nov 14, 2008 | 03:44 PM
gregsworld's Avatar
gregsworld
Exact same issue here. Discovered it due to the cruise control not working after I installed chrome switch housings. First mistake was attempting to bend the piece that taps the switch. Don't do this. It will break immediately. Ask me how I know. After ordering replacement handles from Kuryakyn, it still would not press the switch hard enough. I rigged up a clip on piece of metal temporarily, but I am concerned this will not permanently remedy the problem.
I too will try the shrink wrap. I have a 2400 mile trip planned for June and really would hate to be on the road and lose my cruise control. Any additional ideas would be much appreciated.
Greg
Old Nov 14, 2008 | 04:18 PM
hotrodsandharleys73's Avatar
hotrodsandharleys73
Same problem with mine after putting a m/c kit in. Shooter has it right loosen the control screws and make sure the assembly is tight (meaning the control and m/c housing is up against the throttle grip portion).
Old Nov 14, 2008 | 07:38 PM
Just Me's Avatar
Just Me
My 07 SB did this also and I finally found the only thing that worked flawlessly was to JB weld a bb to the flat part on the handle that activates the switch. I'am sure there are many other glues out there that will also work.
t059736
Sep 28, 2013 12:52 PM
xxINKxx
Jan 21, 2013 11:01 AM
jckazz333
Oct 29, 2011 11:08 AM
stilup
Jun 20, 2011 06:58 PM
Alabamaslammer
Feb 15, 2009 10:43 AM
