speedo stopped working ne ideas?
I finally got my 99 fixed, it was a biatch. When you turn the switch off/on, does the odo or anything register? Or is it totally dead? The sensor that triggers the speedo/odo has a connection under the seat, or it does on my 99. I would check that first, since you were in that area changing the battery. Those sensors run about $65 or so, back when I bought mine. It has a large TRIANGLE connection under the seat, with red, white and black wires, and the sensor is down on the tranny (I think) and is held in with one allen head screw. Good luck, and please post back.
I expect your demon is under the seat. Like I said, it is a large, probably 3/4" TRIANGLE connection, if I remember right. And it has a red, a black, and a white wire. 3 total.
Randy D.
Last edited by RandyDowdy; 04-26-2010 at 05:10 PM. Reason: correct description under seat of harness.
Good luck, keep us posted. RD
