So I've determined that there is a fitting that is pressed into the front end on the bike, and the speedometer cable unscrews of the the back of that fitting. I can upload pictures if anyone thinks it will help.
I've found my speedo cable is broken in half so I'l be replacing it anyway.
I got a 94, and there's a tiny set screw that holds the speedo cable in down at the bottom of the fork. I was stumped when I first tried to take mine off untill i really wiped all the grease and road grime off down there and saw the little pin hole with the set screw.
