2004 1200R Questions
Old 07-07-2010, 01:49 PM
geminimoon66's Avatar
geminimoon66
geminimoon66 is offline
Stage I
Default 2004 1200R Questions
Have a 2004 1200R and trying to find out if gas tank and fenders from a 2007 1200C will fit.
I would also like to swap the stock tach/speedo for a single 3.5" speedo that I have. Problem is that the wiring plugs are different. Any way to get an adapter of some sort to make this work? Speedo I want to use is also from a '07 1200.
Any help, ideas, or suggestions would be appreciated!
Thanks to all!
Old 07-07-2010, 02:13 PM
veritas.archangel's Avatar
veritas.archangel
veritas.archangel is offline
I know that the tank won't fit due to the holes it has for mounting the fuel pump. Anything '04 thru '06 will fit. In '07 they went to fuel injection so all the later tanks have the fuel pump in them.
The fenders should, though.
Old 07-07-2010, 09:27 PM
punkmxcn's Avatar
punkmxcn
punkmxcn is offline
As far as the wiring , you can always splice and solder.
chopperone
09-25-2014 12:33 PM
ReidRik_Von
06-09-2014 12:10 AM
dustinn3
06-05-2013 03:18 PM
six_strng_slnger
06-17-2011 09:16 AM
TARTAN2
11-12-2007 08:19 PM
Quick Reply: 2004 1200R Questions
