thumb screw cruise control????
  #41
Old 07-15-2019, 09:45 AM
Jackie Paper's Avatar
Jackie Paper
Jackie Paper is offline
Received 4,575 Likes on 3,822 Posts
Well, first things first. Call it by its proper name. Suicide Cruise Control Switch.. SCCS for short. Leave it loose.
The first time my buddy was showing me his 38 Harley, between the spark advance, foot clutch and no return spring on throttle let alone two cables, I guess Harley should be allowed for one idiot switch still on there.
  #42
Old 07-15-2019, 10:04 AM
twoglides13's Avatar
twoglides13
twoglides13 is offline
Trying to use it for cruise control will keep you occupied in case you are tired of talking or singing to yourself.
  #43
Old 07-15-2019, 10:09 AM
lewk's Avatar
lewk
lewk is offline
This is a lot safer to use:
  #44
Old 07-15-2019, 10:10 AM
VAFish's Avatar
VAFish
VAFish is offline
Received 3,130 Likes on 1,626 Posts
I don't get those saying it is a suicide switch. All it does is hold the throttle in one position, unless you really crank down on it, which will probably break the little plastic pieces, you can roll the throttle off. And worst case even if the throttle sticks wide open all you have to do is pull in the clutch and that will disconnect the engine from the rear wheel. Your bike has a rev limiter, won't hurt a thing. If you don't know how to use a clutch, well I can't help you there.
The following 5 users liked this post by VAFish:
apache snow (07-15-2019), cacomly (07-16-2019), hdbob2006 (07-15-2019), Hey Man (07-15-2019), HotRod917 (07-16-2019)
  #45
Old 07-15-2019, 10:16 AM
MoneyFor's Avatar
MoneyFor
MoneyFor is offline
+1 on that
  #46
Old 07-15-2019, 10:23 AM
IronAss's Avatar
IronAss
IronAss is offline
Received 12,221 Likes on 4,771 Posts
I’ve used them for decades with no problems. I haven’t flown for a while but when I was, most light aircraft that used a vernier throttle had friction locks on them.
  #47
Old 07-16-2019, 04:48 AM
HotRod917's Avatar
HotRod917
HotRod917 is offline
Hell yea on that.!
  #48
Old 07-16-2019, 02:11 PM
cacomly's Avatar
cacomly
cacomly is offline
Exactly, use them all the time when I was flying. Tighten them up just enough to hold the throttle in position when you remove your hand.
  #49
Old 07-16-2019, 03:10 PM
handirifle's Avatar
handirifle
handirifle is offline
Received 1,649 Likes on 1,108 Posts
Pretty hard to compare flying to riding a bike. Its not like another plane is going to pull out in front of you causing a panic stop.
  #50
Old 07-16-2019, 05:00 PM
Jackie Paper
Or pass you and pull back abruptly in front of you.
However, like people who use it, you can easily over ride it by twisting the throttle back.
I simply never use it since I take a break ever hour or so. And my FI throttle spring is so weak, just hanging on holds the throttle open. My friend has that plastic palm lever like shown above. Makes no sense to me. I guess I must just lean back and hang on while others lean forward with their hand off the throttle.
1NewHDGuy
06-16-2014 06:46 PM
R_W_B
11-30-2010 09:33 AM
plane
08-12-2008 10:08 AM
humpyy57
06-18-2007 02:15 PM
MacAttack
02-09-2007 09:31 PM
Quick Reply: thumb screw cruise control????
