Replacing spark plug wires
The box says that they are for 04-06 so im pretty sure the set is right.
I have a set of black SE wire on my XL50 and they are like that and like was said they will only go on one way and the bend goes to the coil. The are alot thicker than the stock wires so I had to route them a bit differant, but it ended up looking better anyways. The are good wires for the price.
Screaming egal spark plug wires instalation
Just got from the local dealership a new set of spark plug wires to fix the backfire and engine skip so that it will not lead to a break down on the road or dO any internal damage to the barings and pistoN rINGS OR Even SCRape the bore My question Is to do a good instalation on my own I will need to Remove the gas tank allen screw for better acsess does anyone know the torque specs of a 1200c 2011 HD
I have the orange screaming eagle plugs and I am pretty happy with them. Install was just as simple as you described in your first post. As another use stated, you should use a dab of dielectric grease as it helps keep out moisture and as a means of lubricating and sealing rubber portions of the connector without arcing.
