2 up seat help
2 up seat help
My wife wants to ride on the back of my Nightster once in a while. I like the solo setup but it looks like I will need to get a 2 up seat to put on when she wants to ride. I will still be using the solo set up most of the time so I do not want to scratch the fender up. Anyone use or know of a seat that will not mare the fender? Is it even possible, it did not take long for the fender under the solo to get pretty beat up.
Thanks
RAL
Thanks
RAL
Howzit
Definitely use nylon washers under the metal tab mounting tab between the fender and the mount. Also I have a piece of wetsuit neoprene that i lay on the fender before placing the seat. Another option is that nonslip gripper material you place under rugs..to prevent them from slipping .Just cut a piece the shape and size of the seat.H
