milky white primary fluid
Old Dec 13, 2022 | 03:55 PM
pgreer's Avatar
pgreer
What oil are you using in the primary? Are any of the other oil levels affected, like there could be a transfer?
I'd drain the primary oil and pull the outer cover and clean it out as well as you can. But I would avoid harsh chemicals near any rubber seal or clutch disk. I'd then use the same primary gasket to reassemble and fill with the correct oil and take it for a long ride. At least 30-40 minutes or 40 miles so everything is at full operating temperature. In Pennsylvania this time of year it may take even longer to reach operating temperature. Then I'd check the primary oil level again to see how it looks, and if the level has changed.
One thing you want to avoid is starting the engine and not riding it enough to get up to operating temperature so that moisture in the engine, trans and primary can get hot enough to boil off moisture. If you are finished riding for the year, put it on a tender and don't start it again until you are ready to take it out for a long ride.
Paul
Old Dec 13, 2022 | 06:15 PM
John Harper's Avatar
John Harper
The Xombies arise again! The coming winter months beckon them! Be gone, foul spirits!
John
Old Dec 13, 2022 | 07:22 PM
Rob Roy's Revenge's Avatar
Rob Roy's Revenge
John
Zombie threads never die, John, they just eat away at your heart and soul forever and a day.
Old Dec 23, 2022 | 07:07 AM
sorensentyler's Avatar
sorensentyler
Originally Posted by jerryw618
water from where ????? sportys are air cooled !!!!!! and if water could leak in wouldnt primary fluid leak out ????
🤣 wow...
Old Dec 23, 2022 | 07:14 AM
Hey Man's Avatar
Hey Man
Not if the entry point was higher than the fluid level.
Old Dec 23, 2022 | 01:58 PM
Rob Roy's Revenge
Gasoline contains petroleum hydrocarbons, when gasoline is burnt with air, the hydrocarbons in the fuel react with the air to produce Carbon Dioxide (CO2). Water (H2O) and Nitrogen (N2)
If an engine is only used for short runs, the motor doesn't get up to it's optimum working temperature and water condensation can build up in the oil which turns it a milky white colour.
To avoid milky oil, one must take the motorcycle on a long run at least once a month to get the motor up to it's optimum working temperature and boil off the water that was present in the oil.
Continually running a motor with water in the oil for short journeys will cause damage to the engine.
Old Dec 23, 2022 | 02:12 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
Maybe so, but this 11 year old post is about Transmission and Primary lube.
Fastfwd
Dec 16, 2022 08:33 PM
UltraClassicElectraGlide
Sep 3, 2014 05:55 PM
skiddd
Jun 28, 2014 05:53 PM
Nate88hd
EVO
29
Apr 3, 2011 08:22 PM
dive328
Mar 1, 2009 08:30 PM
