New Screamin' Eagle Round Stage 1 AC
Old 10-29-2011, 11:10 AM
TKDKurt's Avatar
TKDKurt
TKDKurt is offline
Default Questions about New Round Stage 1 AC
I am thinking of installing the new Screamin' Eagle Round Sportster Stage 1 air cleaner. This one:
http://www.harley-davidson.com/gma/g...bmLocale=en_US
Some questions:
1. Is anyone running this yet?
2. Can you provide the installation instructions (or a link to them)? You can usually download them after you hit "Purchase Online" but that isn't an option here. (It says contact the dealer for availabiltiy.) I want to see if I should install myself or have the dealer do it. I'm not sure what changes are necessary to switch from the "ham can" to a round AC.
3. I am running SE Street Performance Slip-ons, which I really like. Will this A/C pair well with these pipes?
4. I know I will need a remap. What is the going rate for that at the dealer?
5. I have already seen a performance increase over stock with just the SE SP pipes. Will there be a further noticeable improvement with this AC and remap? I understand that it is likely it will make the engine run cooler?
6. I understand the remap will make the engine run less lean (which is why it runs cooler). How much will this decrease gas mileage?
7. I don't want to run the AC naked and then have to deal with a rain sock or sucking in water, so I don't want to do just a trim ring on top. The only cover for round AC's I see from HD is this plain chrome one they call the "Smooth Air Cleaner Cover".http://www.harley-davidson.com/gma/g...bmLocale=en_US
Are there other choices from HD or elsewhere?
Thanks in advance!
Old 10-29-2011, 12:45 PM
WRAITH's Avatar
WRAITH
WRAITH is offline
The A/C will come with instructions. Anything from HD will fit like stock. You will need a new map. It will probably cost around $150. You will notice some extra performance and a slight decrease in fuel economy. If you keep the cover on, the rain will not affect the engine.
Old 10-29-2011, 01:30 PM
PAsportster's Avatar
PAsportster
PAsportster is offline
here is a pic of mine easy to install .... get the KN filter to replace the SE filter...
Old 10-29-2011, 01:39 PM
CosmoKramer's Avatar
CosmoKramer
CosmoKramer is offline
The kit will come with everything you need. It should be very similiar to the screamin eagle stage 1 kit just with a round backing plate. So I would refer to these instructions to see if you can handle it. Pretty simple installation...but that depends on your own capability and tools...only you can make that call on whether to do it yourself or have the dealer install:
http://www.harley-davidson.com/en_US...ts/-J03942.pdf
Actually you have this backwards....running lean means running hotter. The EFI sportys run lean from the factory to meet emissions requirements.
Old 10-29-2011, 01:53 PM
131tman's Avatar
131tman
131tman is offline
AN Big Sucker w/8" cover
MarkFXSTC
06-15-2015 11:47 AM
joelonmackey
07-07-2012 04:16 AM
hockey8787
03-06-2011 10:47 PM
ggf
02-08-2008 02:08 PM
FORDTUFF
07-08-2007 12:21 AM
Quick Reply: New Screamin' Eagle Round Stage 1 AC
