Nightster Winter Makeover
I chopped my rear fender and had it powdered flat black. A few weeks ago I dropped one of the fender spikes directly onto it, dead center from quite a ways up there, and about **** myself at the destruction I was about to witness. Nope, not a mark anywhere...can't even see where it made contact.
I don't doubt it will chip, scratch, etc...but nothing I have ever had powder coated at my industrial PC shop looks different than the day I brought them home. Truck, motorcycle, and dirtbike parts alike, they all love it. A needle file will definitely take some **** off though.
You prob. have more hands on PC experience than I do though.
Parts look great Ergo!
Had time yesterday to put the cam cover and the primary back on. Once they were in place we pulled it off the chain it's been hanging from and (very carefully) set it on the bench. Took the day off from work and will be putting the rocker covers back on, and then who knows from there. I'll be alone most of the day in the shop and can't mount the motor in the frame by myself so I'll do what I can do. I'll post pics later. We'll probably put the motor and frame together this weekend.
Finished reassembling the motor.
Then there was the frame...went to pick it up. As I walked in the powder guy was swearing up a storm. Just before I walked in he was waxing it, final step before wrapping it up so I could take it home, and he or someone there put a scratch just below the steering head on one of the down tubes, right on the outside where it would be hugely visible. He was beside himself. The thing looked gorgeous, perfect, except for that small but highly noticeable scratch. So they're going to do the whole thing over again. Said I could probably pick it up on Friday.
One thing I wanted to mention about the cam cover, for anyone who might be thinking about chopping it or just taking it off to have it powdercoated or painted. Most of the motorheads will know this of course, but for those that may not be aware, when you pull the cover you have to be extremely careful about the cam gears...they will slide out with the cover if you're not careful. If they do slide out, even a little bit, make sure when you push them back in you get them in exactly the same position they were in before you started. And if there's any doubt, pull out the manual and check the alignment against the cam gear diagram. All the gears have registration/alignment marks on them. Put a socket on gear 5, rotate the engine until they are in proper position and make sure the marks line up as shown.
This happened to me when I took the cover off after painting the engine. I was afraid they got out of alignment so I checked and sure enough I was off by two teeth on one of the gears. It pays to check.
Hopefully, I get the newly coated frame on Friday. I truly hope it looks as good as it did today, minus the scratch. Damn it was beautiful.
