turns over no spark
Old 03-18-2012, 09:06 AM
hardtailrider's Avatar
hardtailrider
hardtailrider is offline
1st Gear
Default turns over no spark
I have a 90 sportster and it lost throttle power while on a ride. All electrics were working checked for spark and there was none, i have changed the coil and checked battery connections and i still have no spark. Any ideas???
Old 03-18-2012, 09:39 AM
Scuba10jdl's Avatar
Scuba10jdl
Scuba10jdl is offline
Start from the easiest and work your way back.
Plugs, plug wires, coils, wiring to the coils, timing plate, miscellaneous wiring in the ignition circuit. One of these will be your problem, but it's up to you to figure out which. Best of luck.
Old 03-18-2012, 12:20 PM
Mike07FLHTC's Avatar
Mike07FLHTC
Mike07FLHTC is offline
As said plugs and wires good place to start. I have seen new plugs that didnt fire. Good chance its your ign mod. in the cam cover or the black ign box under your side cover. You can replace both with after market all in one unit that fits in the cam cover.
mtrembley
04-08-2014 09:35 AM
EvilWayz
Ironhead
13
09-07-2010 05:40 PM
Tom4snow
Ironhead
05-26-2009 11:56 AM
shovelpan
11-26-2008 06:37 PM
spammer89
07-31-2008 02:27 PM
Quick Reply: turns over no spark
