Ironhead A place to talk about Ironheads.
no spark
Old May 23, 2009 | 06:51 PM
Tom4snow's Avatar
Tom4snow
Stage I
Default no spark
just got a 71 ironhead going through it new points coil plugs and plug wires still no spark points set at .018 will get a spark when turn key to off position any ideas?
Old May 26, 2009 | 10:35 AM
d_slat's Avatar
d_slat
it almost has to be something with the points system. are they opening and closing when you turn over the engine? a picture of the inside of the timing cover would help us help you...or did you find it already?
Old May 26, 2009 | 11:56 AM
megawatt's Avatar
megawatt
Since you posted back on the 23rd, you probably have found the problem by now like d slat mentioned but I'll toss in my take on this. What you describe sounds like you have the wire between the coil and the points not connected to the moveable point or there is a ground in that wire. The other thing is that you may have a shorted condenser. This is assuming you have set your .018" gap while the point rubbing block is on a high point of the ignition cam lobe (ie. the points open and close when the engine is turning).
Darin Edwards
Sep 18, 2015 01:45 PM
FXD_noob
Nov 14, 2013 01:32 PM
sdurkee74
Jun 18, 2011 12:40 PM
av8or
Jul 6, 2010 10:40 PM
my73
Ironhead
Jun 7, 2006 10:13 AM
