Burly Help
Old Mar 22, 2012 | 10:03 PM
odie-in-az's Avatar
odie-in-az
Originally Posted by barrygreen
Was your kit in a burly box?
I had no problems with mine at all, or I was lucky.
Yeah, it was all in a Burly Box. The extension wires for the running lights were a different gauge but the end you pull out of the plugs are the same as whats on the extension wires. The problem is the the other connector end of the extension wire is not compatible with the end you pull out from the oem. It looks like the wire extensions they gave me are meant to be cut and spliced together on your own. Did your wires just snap together?
Old Mar 23, 2012 | 12:47 AM
TexFF's Avatar
TexFF
Sorry I didn't read this earlier. They should real easily slide into each other as long as you have them with the both correct side up. Mine slid together very easily. So easily they don't really stay together very well w/out solder or heat shrink. You should have absolutely NO problem mating them together. there are 6 wires(blue & black ONLY wires in a separate bag) that are for turn signals. I didn't mess w/them @ all so IDK if they are a different size. I hope you get it figured out. Keep posting any problems/questions in this thread & I'll follow it & help w/anything I can. Good luck!
Old Mar 23, 2012 | 05:59 AM
barrygreen's Avatar
barrygreen
Yes my extensions fit both the factory wires and connectors
Old Mar 23, 2012 | 07:08 AM
schwingding's Avatar
schwingding
Originally Posted by odie-in-az
How in the F%^k do you get these monkey F%^king wires together. Sister raping kit!
Yet another reason I'm glad I simply soldered the extensions in. You never listen.....
Old Mar 23, 2012 | 01:23 PM
Boots1986's Avatar
Boots1986
I just recently installed 14" chrome narrow apes on my bike and had no problems connecting all the wiring using the Burly kit. The connections are not super tight but that gets taken care of once you use the shrink wrap they give you in the kit. If you're still having troubles let me know.
Old Mar 23, 2012 | 04:39 PM
aivanne's Avatar
aivanne
I ran into the same problem with my Burly kit, or at least i gave it a good 30 seconds of thoughts and I should have looked further....
Anyways, soldered everything right away.....that's what should be done anyways IMO.
Old Mar 24, 2012 | 02:19 AM
pbr rebel's Avatar
pbr rebel
as far as my lights, I pickt up a kit so i can use my stock wires..i didn't have to extend my runing light wires.
Old Mar 24, 2012 | 09:42 AM
odie-in-az's Avatar
odie-in-az
I ended up using soldering the wire end and shrink wrapping them. Everything is wired and works except my horn. The horn is wire correctly but not working. There's no specific fuse for the horn so no dice there. I never use it but not having it work is gonna bug me until I fix it. Also the plug for my left hand control, to include my horn, 4 connectors inside the plug broke. Something must not have been lined up right. I cut that plug and did a direct splice and everything works....well except the horn. Anyway, I learned why I'm not an electronic engineer.
You were right Schwingding....you were right.
Old Mar 24, 2012 | 01:33 PM
TexFF's Avatar
TexFF
Mybe the wire is pinched under the control? Are you 100% sure it worked right before you did this?
Old Mar 24, 2012 | 08:57 PM
odie-in-az's Avatar
odie-in-az
Okay, this is nuts. I'm riding down the freeway and I hit the horn button out of curiosity, and the horn was working again. Weird but what the hell...
