Burly Help
Old Mar 22, 2012 | 06:38 PM
odie-in-az's Avatar
odie-in-az
Default Burly Help
Can anyone help me connect these wires? I can't seem to figure out how the wires connect. Do you have to force them? Seems like they should snap together but I don't want to force them and break something. Can anyone help?
Old Mar 22, 2012 | 07:00 PM
92oldskoolxlh's Avatar
92oldskoolxlh
You should just be able to slide them in its going to be tight because there made so you dont have to crymp them. It will take some effort after that if you want to make sure they will never come loose grab a pair of pliers and crymp the **** of them.
Old Mar 22, 2012 | 07:42 PM
odie-in-az's Avatar
odie-in-az
They don't even act like they want to connect. How in the hell do these connect? I've tried forcing them and everything. Nothing is working!!!
Old Mar 22, 2012 | 07:54 PM
92oldskoolxlh
It could be a bad connector on the end or maybe one of the ends was closed a slight bit? Best bet is to go to autozone get a box of the connectors and snip those off and put new ones on.
Old Mar 22, 2012 | 08:11 PM
odie-in-az's Avatar
odie-in-az
How in the F%^k do you get these monkey F%^king wires together. Sister raping kit!
Old Mar 22, 2012 | 08:39 PM
pbr rebel's Avatar
pbr rebel
You have to pop off the back of the connector, I used my olz sewing screw driver, sum use a papper clip but it didn't work for me. Ie there are these little tabs that that hold the connectors in and you have to unclip them basically using a tiny tool. Good luck I hope I made alittle ground for yah. I had the same problem and had to figure it out on my own.
Old Mar 22, 2012 | 09:08 PM
odie-in-az's Avatar
odie-in-az
It's not the plugs I'm having a problem with, it's splicing the wires together. The wires they give you look like they should connect very easily to the wire when you pull it out from the plug. It doesn't though. It's really pissing me off! Wire to wire, not wire to plug....
Old Mar 22, 2012 | 09:26 PM
barrygreen's Avatar
barrygreen
Sorry man, that's one of those things that needs to bee seen first hand, got a magnifying glass to look for the problem?
Old Mar 22, 2012 | 09:53 PM
odie-in-az's Avatar
odie-in-az
I'm gonna do as 92oldskool suggested and snip the connectors off and put my own connectors on. There is no way to splice the wires together with the wire kit that Burly gives you. They should say to buy your own splices. The wires go into the plugs no problem but the wires don't splice with their connectors. Everything else in the kit is ****. Those wires pissed me off so bad......okay, I'm done. Thanks for letting me vent!
Old Mar 22, 2012 | 09:56 PM
barrygreen's Avatar
barrygreen
Was your kit in a burly box?
I had no problems with mine at all, or I was lucky.
