push start question
Old Jan 10, 2013 | 08:55 AM
Agiuliano10's Avatar
Agiuliano10
Default push start question
been searching on here how to push start my bike and i have it down now except for one thing...everyone says to "pop" the clutch. do they mean to just let it go completely so it engages quickly or are you supposed to gradually let out the lever?...also just in case the bike doesnt turn over, how bad does it buck when in gear but it doesnt start? are my chances of goin down pretty good? haha
Old Jan 10, 2013 | 09:00 AM
Scuba10jdl's Avatar
Scuba10jdl
Just let it go all the way at once. Also, use 2nd or 3rd gear to make turning the engine over easier. I get a buddy to push and then right when I want to pop the clutch I jump up and land on the seat at the same time I let the clutch out. Helps keep the wheel from slipping.
Note: It looks like your sig pic is a Nightster. You're going to have a much harder time bumping an EFI bike than a carb.
Old Jan 10, 2013 | 03:50 PM
DravenGSX's Avatar
DravenGSX
2nd gear, about 10 MPH, let her rip. It does help to jump on the seat. If it doesn't go, the tire will just slide for a few feet.
Either way, it can't be very good for just about any part on the bike.
Old Jan 10, 2013 | 04:16 PM
John Harper's Avatar
John Harper
If your battery is too low, the EFI will not operate. If your fuel pump won't power up, you're done.
John
Old Jan 10, 2013 | 04:18 PM
Agiuliano10
just went ahead and got a new battery...thanks though, i feel like its good to know how to push start anyway just in case
Old Jan 10, 2013 | 08:45 PM
Knights2TheEnd's Avatar
Knights2TheEnd
I had to push start my bike one time, thank god I was on a hill lol. The only "mistake" I did was start it in 1st gear, it would have been alot easier and safer in a higher gear, like 2nd or 3rd
Old Jan 10, 2013 | 08:53 PM
QC's Avatar
QC
John
The whole system in an EFI bike needs enough juice in order to fire up. You may have enough to turn the pump on but not enough to do the rest.
Old Jan 10, 2013 | 08:54 PM
SportyPig's Avatar
SportyPig
2nd gear usually works better. However, your avatar pic appears to be EFI bike. They won't jump start, unless the problem is the starter. Gotta have battery to run the fuel pump.
Old Jan 11, 2013 | 04:14 AM
Proteus's Avatar
Proteus
Exactly. Been there, done that.
buying a new battery: OK
But let check your regulator, could be toasted, mine did, changed by my indy under warranty, there was a recall on all sportsters built between oct 2011 to march 2012, IIRC.
Barsknos
Jul 31, 2018 04:11 PM
Ketron10a
Jun 25, 2013 12:06 PM
Mercyfulfate
Oct 23, 2012 06:45 AM
casper gomez
Sep 3, 2010 01:14 AM
Superglide 04
Apr 24, 2008 12:57 PM
