Throttle cables?
Old Jan 14, 2013 | 04:28 PM
JeffJA's Avatar
JeffJA
Default Throttle cables?
i have an 09 custom, i bought some braided cables that came off an 07 nightster, they should be the same, correct?...the braided ones that came off the nightster have small ***** on the end of the cables (grip side) and the ones that are on my 09 have tiny barrel shaped ones...will these not work?
Old Jan 14, 2013 | 04:41 PM
Ragnar Danneskjöld's Avatar
Ragnar Danneskjöld
Hmm...if I understand correctly, then your "barrel shaped ones" are just the brass ferrules that the cables slide into.
Look like these?
http://www.sampowersports1.com/images/DSC08340.JPG
Old Jan 14, 2013 | 04:45 PM
JeffJA's Avatar
JeffJA
yes!..
Old Jan 14, 2013 | 04:47 PM
mjolnir's Avatar
mjolnir
Yep, the ball should be fixed to the cable, and fits into the barrel. So it sounds like you're just missing those two little pieces.
Ragnar Danneskjöld
Alright, well, be careful with these they're easy to lose. Open the throttle housing and pull the cables + ferrules out of the grip. Don't drop 'em. They'll slip right off the cables, then just put them on your new cables. They're a pain in the *** to put back in so loosen off the slack adjuster on your throttle cable to make it easier.
Old Jan 14, 2013 | 04:50 PM
mjolnir's Avatar
mjolnir
And if you don't own picks, they will make things much easier.
Old Jan 14, 2013 | 05:07 PM
JeffJA's Avatar
JeffJA
huh, the "ball" ends on the braided cables "look" bigger, almost like they should be used without them small brass ends?
Old Jan 14, 2013 | 05:10 PM
Ragnar Danneskjöld
I assure you that's not the case. However, can you get a side-by-side picture of the cables?
Old Jan 14, 2013 | 05:13 PM
JeffJA's Avatar
JeffJA
na, the bike is still all together, i have all the parts to install some 12" apes, i just happen to be looking at the braided cables today, maybe it was just me, i hope to start the swap soon.
Scooby1426
Audio Systems
Mar 11, 2018 06:29 PM
JoeEMT
Jan 12, 2012 08:32 PM
elcamino
Exhaust System Topics
Mar 14, 2008 09:01 AM
rkcrwlr
Sep 18, 2007 03:49 PM
dog155
May 7, 2007 08:43 PM
