Starting problems
2007 Sportsters are well known for having chronic moisture/corrosion problems in the fuse-block/relay area.
Remove all of the fuses and relays. Clean the contacts on the fuses and relays, and then coat the contacts with dielectric grease and reinstall. You can find the dielectric grease at any auto parts store.
Hi again I sent the bike to the shop , they said the antenna for the TSSM module went bad , replaced it cost me 13.50 + labor starts and runs great now not one single starting issue.
ghost183
Electrical/Lighting/Alarm
27
Jun 1, 2018 10:15 AM
dlrshort
May 10, 2011 02:50 PM
