Ignition module to harness connector.
Welcome, good question to start with. Always wondered about that myself. I've got a 1991, so wire harness is similar if not the same.
I know that there are thousands (if not millions) of electrical plug connectors, must be job security for wiring design engineers.
If you can figure out the name of the connector (I've heard the name Deutsch, although I'm not sure of the reason for the name or if I am correct}. Some obscure Harley engineer must have decided what to use from an electrical wholesaler's catalog, it sure is not rocket science.
Just have to put pins or sockets on, have no idea how easy that might be. My bike has intact original wiring.
Do some googling, learn something new, and tell us what you found.
And welcome aboard.
John
And welcome aboard.
John
So you just need the connector at the end of the wire harness? You need it to connect to the ignition module only, right?
I don't think you need the adapter as suggested above. Show us what the ignition module end looks like and I'm sure you can find an answer.
Male or female end, it should be available somewhere, don't give up, grasshopper.
Joh
Joh
The Phoenix
11-19-2009 09:54 PM
lowglide88
03-31-2009 04:00 PM
