Primary Problem
Old Apr 18, 2013 | 09:07 PM
Monster143's Avatar
Monster143
2nd Gear
I feel your pain. Nothing like riding a mountain road and realizing your rear tire is covered with primary fluid.... Look forward to the pics
Old Apr 19, 2013 | 07:18 AM
cavalier2000's Avatar
cavalier2000
Ok so my "lets fix my bike" evening turned into rebuilding wheel cylinders on my jeep and getting pissed off so the pics.... Are shitty but I can snag some when there is light if that will help.
As far as location
Stand on the right side of the bike
Locate the starter
Now look just to the rear of the starter to see a wire (speed sensor) then right next to it is a rubber hose coming out
And now for shitty pics (follow the dirty finger)
Um... Follow the pen.. Hard to see in the dark and find your spot but you can also see the sensor
Yea it's dark here now so give me 10 hours when it's am and I will try and shoot a better pic
Mind you mine is routed WAY ***** wrong it is supposed to be routed up and zip tied to your battery tray apparently. But since mine is routed wrong... Primary fluid is EVERYWHERE. Sucks
Old Apr 19, 2013 | 08:24 AM
John Harper's Avatar
John Harper
In the last picture, your finger is on the transmission vent tube. You can see the hose clamp where it connects to the fitting coming from the transmission. If that is the hose that is leaking, that's what we are talking about. It's supposed to run upwards and vent under the seat, I believe. It may not be routed properly.
John
Old Apr 19, 2013 | 09:13 AM
cavalier2000
Right mine is routed terribly
Old Apr 24, 2013 | 10:06 PM
Monster143's Avatar
Monster143
2nd Gear
OK, so I talked with a guy I know who is very big into Sportsters (been wrenching on bikes for almost 20 years, one of the few people I know who still knows how to work on everything from flatheads to Twin Cams)
Told him the problem. Said he is almost 100% sure it is a blown crank seal. Seal is broke, cracked etc, causing crankcase pressure to go into the primary and cause the fluid to be pushed out the breather, clutch cable, etc. Said it is a fairly common problem with newer model sportsters.
Screw it, I will give it a try and let you know how it goes
Old Apr 26, 2013 | 05:58 AM
cavalier2000
Hmm take pictures while you do it.
lip
Feb 28, 2013 11:34 AM
Ultrascott
Aug 3, 2012 04:40 AM
my dixie wreck
Jun 28, 2012 12:32 PM
gpp
Jan 27, 2008 04:30 PM
hammertime
Dec 2, 2005 06:39 AM
