Electrical problem?
Old Feb 1, 2014 | 04:15 PM
meacham's Avatar
meacham
Stage I
Default Electrical problem?
Hey everyone. New to the forum and just got my 2007 Harley Nightster. I just replaced the battery and there's a slight hesitation when first starting up. When I'm riding everything is fine but sometimes while stopped at intersections the battery light and check engine light come on. When I pull away and get up to speed both lights go out. Any thoughts?
Old Feb 1, 2014 | 04:22 PM
cHarley's Avatar
cHarley
You need to have your charging system (stator and regulator) checked. The battery light and check engine light coming on indicates a low or loss of charging voltage.
07's are also notorious for corrosion problems in the relay/fuse block area, caused by water intrusion. Pull all of the relays and fuses, clean the contacts on all of them and then coat the contacts with di-electric grease and reinstall. You can get the grease at any auto parts store.
MrRich724
Apr 26, 2013 01:09 PM
peeweesenior
Jun 20, 2012 05:20 PM
Swftsildedly
Mar 6, 2012 06:44 PM
Astro
Oct 22, 2010 05:49 AM
Jerseyrider
Apr 29, 2010 10:03 AM
