883 conversion update
Old Mar 30, 2007 | 11:11 PM
PigInaBlanket's Avatar
PigInaBlanket
Default RE: 883 conversion update
I'm keeping the 883 heads as is for now due to not much money issues. There is no valve work needed that I am aware of. Of course a head job or 1200 heads will be better but using just the stock 883 heads should be pretty good by itself.
Take a look at this chart from the NRHS site.
It says The bike that generated this dyno sheet is also equipped with a HurricaneFlow Air Cleaner, Mikuni HSR42 carburetor, SE .536 cams, Supertrapp exhaust system, and Daytona Twin-Tec ignition.
I don't have the cams or the ignition they are using but I do have the SE a/c, stock carb and SE II slip ons which is comparable to their setup so I'm expecting somewhere around 70 max power according to that chart. Should be a good boost.
128 auto the kit comes with cylinders, pistons, rings and gaskets. I went ahead and bought a top end gasket set for an extra $30 I think it was. The guy at NRHS said the bottom row of cooling fins needs to be ground down a little to fit but other than that it should bolt right on.
Kyria Cole
Jun 9, 2021 03:19 AM
jwg In RI
Jul 18, 2011 08:25 PM
schwingding
Feb 19, 2011 08:39 PM
RingDing4Life
Apr 13, 2010 04:16 PM
n0thing43
Aug 3, 2008 07:53 PM
