Lets Swap!!!!!
Lets Swap!!!!!
I have a 2011 FXDF with forward controls. Peg mounts, brake arm, shifter arm have all been PC'ed in gloss black. Normal wear on the rubbers, paint finish on the inner and outer primary is excellent. Scrape on the bottom of outer primary from cornering to aggressively.
Would like to find some one who wants to trade me their mid control set up for my forwards, can send Pics. PM me thanks
I don't think you would have to swap the outer primary cover. You change the shifter shaft and plug the hole and shift linkage goes up and behind the primary then down again. Shaft is changed to shorter one I believe that does not come through the primary for forward controls.
Roadrider18
01-22-2007 01:28 PM
