The Dyno Room A special room dedicated for Dyno tuning products, troubleshooting and results. All Gearheads and Dyno Operators are welcome here as well as the guys that are new to tuning. Please see the special rules for this section before posting.
DYNOJET: autotune questions (PCV & AT
Old 05-28-2018, 10:24 PM
stroker87's Avatar
stroker87
stroker87 is offline
Default autotune questions (PCV & AT
hey guys!
i have an 08 EG installed rinehart duals with 4" mufflers, air cleaner and when i bought the bike it had a PCV, i added the AT-100 autotune unit uploaded map M15-011-251 witch is for my bike with the same exhaust just different air cleaner put about 100 miles on it been applying the autotune trims when i check it there is no major changes from the start the biggest chat was 10+ in a couple cells, now its down to just between 1 to 3+/- across the map
what i dont know is will there be a time autotune does not make any changes or am i just chasing my tail? bikes seams to be running good i have not done any data logging (need the pod-300)
Old 05-29-2018, 06:06 AM
jbarr1's Avatar
jbarr1
jbarr1 is offline
If you’re down to 1 to 3, you’re done. Just ride it now.
stroker87 (05-29-2018)
Old 05-29-2018, 10:31 AM
stroker87's Avatar
stroker87
thats what i thought just wanted to make sure, thanks!
SavageChopper
07-24-2013 10:21 AM
RAYCE_FLHP13
08-04-2012 08:51 PM
smithbrl
09-16-2011 10:40 PM
jcanrun
06-06-2009 07:20 AM
JustDennis
04-15-2009 12:22 PM
Quick Reply: DYNOJET: autotune questions (PCV & AT
