The General Motorcycle Forum Talk about motorcycles that are not Harleys in here
brake chatter
Old Nov 7, 2023 | 10:12 AM
jrsay's Avatar
jrsay
Stage II
Default brake chatter
I have a 2014 electra glide, it had pretty bad brake chatter so I assumed it needed rotors replaced due to warpage. Bike has 11,000 miles. At this time I replaced my lower legs and chromed out the front end, replaced the wheels, with new bearings, new tires, new rotors and new brake pads. After all that I take it for a ride and have the very same brake chatter. Primarily front and at the first hit of the brakes it does it, any speed, It chatters hard enough the front fender rattles. Could it be faulty abs pulsating at any touch of the brakes? It is almost unridable.
Agitation in
Old Nov 7, 2023 | 02:28 PM
Backforty's Avatar
Backforty
Agitation in
Could be an anti lock brake problem. Maybe a defective wheel speed sensor?, Assuming you installed the anti lock wheel bearing correctly. Also I would rule out the ( new ) rotors with a dial indicator.
Old Nov 8, 2023 | 01:10 PM
Bubba Zanetti's Avatar
Bubba Zanetti
I had it on my old Dyna too. I pulled the pads off and filed the leading edge down so that the pad isn't at a 90 degree angle with the rotor. Stopped the chattering and squeaking instantly.
Old Nov 8, 2023 | 02:57 PM
Spartanden's Avatar
Spartanden
A little chamfer on the leading edge helps remove any vibrations that may come up from use. Good job. And something I do as well.
jrsay
Nov 6, 2023 08:46 AM
Bookie
Nov 18, 2019 05:28 PM
Webo
2014-2024 Touring Models
14
Feb 21, 2015 10:24 PM
billbuzz
Mar 19, 2014 12:23 PM
Da Hawgsta
Apr 5, 2013 03:31 PM
