The General Motorcycle Forum Talk about motorcycles that are not Harleys in here
Pinion gear question
Old Feb 17, 2025 | 02:44 PM
Savoie's Avatar
Savoie
3rd Gear
Default Pinion gear question
I’m got a problem that I’m stumped with. I pulled my cam cover on a 1997 EVO to replace the crappy plastic breather valve with a S&S reed valve assembly. When I pulled the cam cover off my cam came with it. No problem, right? When I went to line my timing marks on cam and pinion gear, I found mark on cam but I have searched everywhere on pinion gear and there is no mark anywhere. Is there a way to time with no mark? Could mark be covered with pinion gear nut?
Old Feb 19, 2025 | 05:48 PM
Hannibal Smith's Avatar
Hannibal Smith
Pinion nut won't cover any marks as it runs "internal" (the nut). The mark is typically a little line at the bottom of a gear tooth. Why the reed valve vs. a quality metal rotating unit?
ETA- I have only used reed valves if the breather bore was totally roached out, not saying it's bad, just curious.
Old Feb 22, 2025 | 05:28 PM
Kevin R's Avatar
Kevin R
It’s hard to see but it’s there. Clean it off real good.
tinymike66
Shovelhead
Nov 13, 2024 02:11 PM
joe40x
Shovelhead
May 2, 2022 08:43 AM
franka
EVO
27
Sep 23, 2020 08:16 PM
fxhawg85
General Topics/Tech Tips
Nov 9, 2017 03:00 PM
terrapin88
EVO
Apr 22, 2013 05:52 PM
