Wrong fork tubes
Old Oct 23, 2014 | 07:50 PM
AlPoppa's Avatar
AlPoppa
3rd Gear
Default Wrong fork tubes
Hello everybody, I have a question to ask. I am replacing my fork tubes on my 04 road king custom and when I ordered the replacements off of ebay they sent me FLST fork tubes size 41mm length 22.25 inch. When I put them beside my road king tubes they where about a inch and a half longer but the same diameter. So my question is this, Can I still use them and what effect will the FLST's have on the bike? i.e. handling, ride height, etc. Thanks in advance I know you guys will school this newb.
Old Oct 23, 2014 | 07:57 PM
dirtdobber's Avatar
dirtdobber
If there is room you can let the tubes go out from the tree 1.5 inches which will give you the stock position. If there isn't room for that to take place I would contact the seller.
Old Oct 23, 2014 | 08:14 PM
mongomark's Avatar
mongomark
Your ride height will be an inch and a half higher, you'll need a spring spacer that's an equal amount longer. All early bikes (prior to 2014) have the 41mm forks. Unfortunately, they're a little on the flexy side. Longer tubes will only exacerbate this. Higher speed sweeping turns won't be as stable and if you hit a bump or road undulation you may notice significant instability. If I was sticking with 41 mm, I'd stay at the stock length.
Old Oct 24, 2014 | 01:19 PM
AlPoppa's Avatar
AlPoppa
3rd Gear
Thanks guys. I'm returning them to the seller for the stock ones.
Old Oct 24, 2014 | 06:46 PM
shakrr's Avatar
shakrr
Do yourself a big favor if you have a little extra cash, and look up CCE top tree they come with new tubes
Old Oct 24, 2014 | 10:44 PM
mongomark's Avatar
mongomark
+1 on this one!
Old Oct 25, 2014 | 02:07 AM
NoHpBagger's Avatar
NoHpBagger
Alpoppa ...I have a set complete chrome from my CVO complete top to bottom, I installed air ride.
Give me a call 302-883-7744
HFS
Nov 30, 2018 05:48 PM
Scootertrash60
EVO
Mar 19, 2016 11:59 AM
cavalier2000
Jan 15, 2012 10:20 AM
sportyscoop
Jul 27, 2008 05:49 PM
taggiascoz
Dec 30, 2007 11:45 PM
