Street Glide navigation issues
You guys are right I went to the HD website 2 yrs unlimited miles. I will bring it in tomorrow. Thanks for all the info. I will most likely pick up the extended warranty.
Just wondering what they go for extended warranties? I will probably start another post or use the search.
BTW, I purchased mine from Kutter in Wisconsin. Since they cannot sell out of state, they have a competitive product that you may want to check out to compare. Jim Palmer is good to work with.
OP, there is a problem with the 14+ Rushmores with the auto-dimming feature. The problem results in the same symptom you're seeing. It could be your issue. If you leave the bike on for 10 or 15 minutes, the screen should come back (if it's the auto-dimming problem). At least, that's the way mine worked.
The 1.18.3 update is supposed to cure this problem. If it's an auto-dimming issue, you should be good-to-go after the update.
Turn the bike on Accessory (without headlight) for 10/15 minutes and see if the screen shows up again. If it does, do the update.
alan
alan
Wow my 15 limited is going to make me a computer nerd to update software often, 3 weeks ago when I got my bike they had to update software before delivery and now this is Jan 19th new release already.
Go to this site: http://www.harley-davidson.com/conte...downloads.html
All the instructions are there on how to update your bike, as well as the software download.
Don't hold your breath, cause the updates only come out about once every 6 months or so. Not as often as we would like... (cause we want to get all the bugs fixed)
Thanks for all the replies guys. I disconnected the battery overnight and reconnected it. Turned the ignition on and the Navigation screen works again. I will check it again tomorrow. If its blank I will bring it in to get looked at.
quinnjim
Sep 24, 2013 10:35 AM
