Screamin' Eagle High Capacity Oil Pan-24400099
Just curious if anyone is running this oil pan.
http://www.kutterharleyonline.com/ha...arch%5E/search
the cost is no-starter for me.
consider the ext. capacity oil pan for my Chev TH350 tranny (in chrome with drain plug) from moroso cost under $100.
yes more oil is good- and that is part of the reason for adding an oil cooler....almost considered adding a 2nd cooler more for capacity.
Mike
Mike
Received 3,988 Likes
I have it on my 12 CVO Road Glide with a 120R.
Oil takes longer to get up to temp but once at temp does not run any hotter or cooler than before (approx 235 degrees )
Does not hang below the frame so no clearance issues however you can not run a oil temp gauge without getting creative.
I put my oil temp gauge sending unit inline to my oil cooler to measure the oil temp before it comes out of the cooler similar to how the temp gauges were mounted on the 03 / 04 models.
Seems to work fine, however i only use it as a reference for temp as i also pick up the head temp from my PV.
If i was making the decision again today about buying the pan. I would not purchase As it adds little value and only causes oil changes to cost more
My opinion
My opinion
